I am creating a graphic in after effects for a video I'm working on in premiere that needs to be at about 50% transparency. Meaning when I move the graphic into premiere I want the video layer underneath to show through. This is what it looks like in after effects, I put a still image behind it to see how it will look.
I tried (after removing the still) to put this project in premiere using dynamic link, and the box and pattern behind the text became a solid off-grey color, instead of transparent. Is there a way to link the project with premiere so that transparency is preserved? Or export the graphic that way and then import it into premiere?
