How to create a BILLION effects like this
Michael Cassidy
on Apr 17, 2017 at 3:50:22 pm
Hi There, I'm looking at doing a project where I can create multiple (Millions, even billions) of the same file playing at the same time i.e. something like this:
Is this available to do in Final Cut Pro / AE / Logic short of Duplicating the same file on a billion seperate tracks?
Cheers
Kevin Camp
Re: How to create a BILLION effects like this
on Apr 17, 2017 at 4:06:56 pm
motion tile would likely work for this. adjusting the tile width and height properties will 'replicate' the image/footage.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Jawad Ahmed
on Apr 19, 2017 at 12:30:41 pm
Doesn't using motion tile only replicates the footage? The real problem will be the audio!
Daniel Waldron
on Apr 17, 2017 at 5:50:50 pm
Hope you have a fast computer. That will be a beast to render.
Pedro Pires
on Apr 18, 2017 at 1:13:10 pm
Hi.
I would suggest you keep a maximum of 4 tracks for each render. For example, render the 16, grab that render and place 4 of those inside the 64 to build it. Render the 64, grab 4 of those and place them inside the 256. Render the 256 and place 4 inside the 1024, and so on. This way you will not need ( and no machine would be able to do it ) to have billions of instances of the same video.
Hope it helps
