Mocha Pro Remove don't track the clean plate
Pablo Levin
on Apr 16, 2017 at 12:36:25 am
Hi all!! I'm having some problems with the remove module of mocha pro 4.
This are the steps that I'm doing.
1) I create the shape layer and track.
2)Then I adjust the track points to have an accurate track.
3)I duplicate the layer.
4) Increase size of inferior layer.
5) I go to remove module (I think this could be the reason: The icon of track (cog wheel) in the inferior layer dissapear).
6) I import the clean plate that I create in PS. I check Use cleanplates Exclusively.
When I render to remove the clean plate is static with out tracking data. So the result is wrong. It remove but with a static image replaced. I don't understand what is going wrong. I just see a tutorial and the difference is that when she goes to the remove module, both icons (en each layer) are visible. In my case only the selected layer icon is visible.
tutorial link:
https://vimeo.com/93455754
