log footage in linear After Effects project
Neil Rowe
on Apr 12, 2017 at 1:13:37 pm
I have 10 bit V-Log footage in premiere with Lumetri Color working nicely. I then export (dynamic link) to After Effects and everything is still fine.
Now I want to switch to a 32bit linearized workspace in After Effects, and this is where it goes wrong, and the footage becomes completely washed out.
I am guessing its because I am still using the 'vlog to Rec709' LUT in lumetri, however I dont know what else I should use.
What is the proper work flow for Log footage in a linearized After Effects project?
Neil
Neil Rowe
Re: log footage in linear After Effects project
on Apr 12, 2017 at 4:47:00 pm
I have also noticed that in 'Interpret Footage' the Embedded Profile of the Log footage is showing as HDTV (Rec 709), and I cant 'Preserve RGB' or 'Assign a different Profile' as they are both greyed out. This is the same with Color Management on and off.
