Make TrapCode Sound Keys choose between 2 value
Touhami Aglagal
on Apr 12, 2017 at 5:07:33 am
Hello, so I'm using SoundKeys, I use one for scaling my video, works great, and an other one for rotate the video but of course it's only rotating in one side, how can I say to soundkeys to one time rotate left (-5°) and the other time rotate right (+5°) ? Didn't found anything on google, or by searching by myself, by the way i'm kinda noob to After Effect, just saying ^^
John Cuevas
Re: Make TrapCode Sound Keys choose between 2 value
on Apr 12, 2017 at 1:18:36 pm
Use an ease expression on the rotation property. ease(t, tMin, tMax, value1, value2)
t is your trapcode soundkeys layer, just pickwhip to it. tMin and tMax are the highest and lowest values of that you want to reference from those numbers. value1 & value2 would be your rotation, in this case -5, 5
I don't have trapcode and used convert to audio keyframes, but your expression would look something like this.
t= thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
ease(t, 0, 40, -5, 5)
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
