Plexus effect
Syed Iqbal
Plexus effect
on Apr 9, 2017 at 5:52:53 pm
Hi folks,
Tell me if there is any way of using an image of an object or person with transparency (PNG) as the base of Plexus plugin. Earlier I thought of projecting the said PNG on a plane inside Cinema 4d as material with Alpha channel and then export that plane object as OBJ file that I can use as my base object inside After Effects using Plexus plugin.
I don't know but I could not get it setup properly. So this was my long and indirect approach. Please guide with the right way of doing this.
© 2018 All Rights Reserved
