Roughen mask edges only
stig olsen
on Apr 5, 2017 at 8:31:23 am
Any way to roughen mask edges only? I have applied a mask to a part of a alpha image but when I apply the roughen edge effect, it affects all the edges in the alpha image.
Best,
Stig
Brent Taylor
Re: Roughen mask edges only
on Apr 5, 2017 at 3:58:12 pm
Another solution would be to cut the mask path and use it to make a shape layer with no stroke and a solid/100% opacity color. Put it right above the original layer, and parent the shape layer to your original layer that had the mask, and then select Alpha Matte in the original layer's TrkMat settings. That should give you the same "mask" but give it the ability to take the Roughen Edges effect.
