NULL object follow animated mask
Stefan Saw
on Apr 4, 2017 at 2:04:41 pm
Hello,
I try to let a NULL object follow a animated mask but AE keeps crashing/freezing.
I generate a mask from a alpha channel (auto trace) copy the mask path postion and paste it into the postion of the NULL object. But AE seems to not like it, and keeps freezing. The mask animation is 3 sec. long in that try out version, later it will be much longer.
My aim is to let particle emitter along the mask path.
What Im doing wrong? Is there any workaround? Is it me or is it AE?
EDIT: OK it seems there is a collision between the path animation and the null object follow. I tried a very simple 5 point animated path and the null follows, but in a kind of weired way...
Richard Garabedain
Re: NULL object follow animated mask
on Apr 4, 2017 at 2:46:29 pm
that is strange...maybe you could try selecting a point on the mask and going to layer-set first vertex and see if that helps at all.
