Hello, I am using CS6 to do this tutorial
The projection ends up being soft and there is also a black jagged line in between the wall and sidewalk solids even when I overlap them.
My comp is 1920x1080, resolution is set to full in ALL comps, and Shadow Map Resolution is at the Maximum 4000.
Any ideas on what this could be?
EDIT:
I was able to get rid of the seam (the black jagged line) by turning off cast shadows on my two solid layers. However, there is still a noticeable loss in quality between the projection and the original image, even at 4000.
