Color Grading and Correction VFX in AE or Premiere?
James Carver
on Apr 1, 2017 at 4:15:50 am
I have a short project where I have done my editing in premiere and my VFX shots in AE. There are about 10 VFX shots which I just copied those specific log shots from premiere and pasted into AE.
What should my workflow be when I want to begin color correcting and grading everything on the same timeline?
Export VFX shots with no grading or color correction > Import into Premiere
If so then which format should I export the vfx shots in order to preserve quality? We shot the footage in 4k raw.
iMac 27" Late 2013
32 GB 1600 MHz DDR3
3.5 GHz Intel Core i7
NVIDIA GeForce GTX 780M 4096 MB
Tudor "Ted" Jelescu
Re: Color Grading and Correction VFX in AE or Premiere?
on Apr 1, 2017 at 12:31:22 pm
I always like to export my VFX shots and do the grading for the whole edit in whatever program I will use to grade later.
Export in whatever fits your workflow: ProRes, DnXHD. DPX...
Tudor "Ted" Jelescu
Senior VFX Artist
James Carver
on Apr 1, 2017 at 4:28:07 pm
Do you match your 3d elements with color correction to its scene before or after you export to your color grading program? Or so you just do all color corrections and grading in your resolve or premiere grading preference?
iMac 27" Late 2013
32 GB 1600 MHz DDR3
Dave LaRonde
on Apr 1, 2017 at 9:35:10 pm
I would do AE work after color CORRECTION so all the colors look right in relationship to one another. Then I would do color GRADING, so you get the look you want.
It's a two-step process. No way around that.
Dave LaRonde
Promotion Producer
James Carver
on Apr 1, 2017 at 10:11:49 pm
Dave yep i agree for sure and that makes sense too, but in AE I have several 3d elements being placed in the footgae that need to blend in. So when my footage has been color corrected should i match up the 3d elements with the footage before exporting to color grade?
iMac 27" Late 2013
32 GB 1600 MHz DDR3
