3d Elements texture troubleshooting
anna ioannidi
on Mar 29, 2017 at 12:25:38 pm
Hello,
i am trying to apply a texture on the extrude object (logo with letters) and i have the following questions & issues:
- Although i apply the texture it is not visible and is black. Why. How can i fix it? I did a few things and now i can see it but i don't know if it is the proper way.
- The texture image although is the same size with the extrude image it looks much much bigger and despite the combinations of UV Repeat and UV Offset it cannot fit perfectly to the extrude image- 3d object.
- I would like the texture image to wrap around the 3d object. Is it possible or i have to create two bevels?
Please help,
Thanks Anna
Daniel Waldron
Re: 3d Elements texture troubleshooting
on Mar 30, 2017 at 12:39:00 pm
Texturing is probably one of Element 3D's weakest points. Precomp your logo and texture into compositions that are the exact same size and work from there. As far as I know, you'll need to create a second bevel to texture the sides of your object.
