How do I create a transparent moving object?
Chigozie Obialor
on Mar 27, 2017 at 4:50:33 pm
Hi guys,I've been very interested in creating videos of the type in the link below where a transparent object is moving over an image but I don't know how,can anyone help explain which effects is that and how it is created?
Dave LaRonde
Re: How do I create a transparent moving object?
on Mar 27, 2017 at 5:11:28 pm
It looks like a masked solid (or a shape layer) with the opacity set to about 35%, and the horizontal scale & poaition are animated using Hold keyframes.
Dave LaRonde
Promotion Producer
Eric Santiago
on Mar 27, 2017 at 7:26:09 pm
To add, try Trapcodes Sound Keys and select the bass waveform as a position key frame.
Once converted to keys, you can select all the keys and nudge earlier so it moves into the note and not on the note.
Hope that makes sense.
