4K render issues
joseph farina
4K render issues
on Mar 22, 2017 at 5:41:35 pm
When I render a file at 3840 x 2160 in After effects I get 2 big white boxes on the top and bottom. Does anyone know why this could be happening and how I can get rid of it? Thanks you, Joe
Tero Ahlfors
Re: 4K render issues
on Mar 22, 2017 at 5:58:10 pm
Some information would be nice. Comp settings? Render settings?
Dave LaRonde
on Mar 22, 2017 at 6:04:41 pm
Also: PRECISE version numbers of AE & OS, media container & codec of footage in question, third-party cards used & driver versions, effects applied to footage in question, use of 2D / 3D, use of time stretch or time re4mapping.
Dave LaRonde
Promotion Producer
joseph farina
on Mar 22, 2017 at 6:29:27 pm
Thank you for answering. I think I figured it out. It seems the h.264 setting was a mismatch with that aspect ratio. I switched it to jpeg photo codec and it worked (eliminating the white boxes) but the render is not that crisp. I'm going to re-render under the animation codec unless you have another suggestion. Thanks again.
Dave LaRonde
on Mar 22, 2017 at 6:41:45 pm
If this is AE CC 3027, do this before you render out again: set the comp's resolution to FULL. Ho half, no quarter, full.
There's some kind of bug that crews up renders, and I don't know if it's been fixed.
Dave LaRonde
Promotion Producer
joseph farina
on Mar 22, 2017 at 6:44:10 pm
Thank you Dave. It was set to full. We are waiting on the animation codec to render out to see if it works.
joseph farina
on Mar 22, 2017 at 6:46:10 pm
Thank you
Dave LaRonde
on Mar 22, 2017 at 7:55:44 pm
It would be helpful if I type "2017" and not "3027", yes?
Dave LaRonde
Promotion Producer
Tero Ahlfors
on Mar 22, 2017 at 6:43:39 pm
[joseph farina] "It seems the h.264 setting was a mismatch with that aspect ratio."
If I remember correctly the Quicktime version of H264 is limited to 2000x2000 resolution.
