Access customized comp name with expression
Andreas Münch
on Mar 21, 2017 at 9:23:40 am
I can rename a comp which is lying in another comp with right click -> rename.
Is it possible to access that custom name with an expression?
Because when I do
thisComp.name
I always get the name it had before.
http://www.andreasmuench.de/
Walter Soyka
Re: Access customized comp name with expression
on Mar 21, 2017 at 3:17:14 pm
What you describe is not renaming the comp, it's renaming a layer. Layer names are also accessible by expressions.
Walter Soyka
Andreas Münch
on Mar 21, 2017 at 4:00:36 pm
Makes sense.
So I´d need to access the parent comp and read the layer name of the current comp.
But that´s not possible in AE, is it?
