Editing premier pro sequence in After Effects
Anthony Qureshi
on Mar 19, 2017 at 4:47:31 pm
I've imported a Premier Pro project into After Effects to finish editing. All of the cuts from Premier are shown in After Effects as pre- comps, so when I double click on the clip, it shows the original, entire clip rather than the cut section I need to edit. I want to add warp stablizer, so even when I turn off "collapse transformation" while its in pre-comp, it still gets stuck "analyzing".
Help?
