Render issues, says disk is full?
Mike Johnson
on Mar 19, 2017 at 7:17:05 am
I tried to render a small project in Adobe After Effects, and after about 7 minutes I heard a "baaa" sound(or something close to it) with a notification that the render failed and "disk full" and that the "file may be corrupt." The flash drive I was rendering it to certainly had enough space, and when I tried rendering it again it failed at around the same time, and interestingly what was left of the semi-rendered file was the same size as the previous one. 4,179,644 KB to be exact. Why is this happening? What can I do to fix it? Help would be much appreciated.
Dave LaRonde
Re: Render issues, says disk is full?
on Mar 19, 2017 at 4:36:14 pm
There's a lot of missing information here, but here are some shots in the dark:
Don't render to the thumb drive. Render elsewhere.
Render an image sequence instead of a movie.
The reason for the first: you might have a dodgy thumb drive.
The reason for the second: you may have corrupted footage in AE.
Dave LaRonde
Promotion Producer
Gary Milligan
on Mar 19, 2017 at 6:05:43 pm
In addition to what Dave says, it could also be that you've reached the file size limit (4GB) of the FAT32 formatted drive.
Mike Johnson
on Mar 19, 2017 at 11:36:19 pm
Well, I guess my flash drive didn't have enough space, even though I'm sure it did. I tried rendering it to my hard drive and it worked! So I guess it was just an error on my part.
