After Effects CC is rendering images that aren't even in this project file?
Anthony Natarelli
on Mar 15, 2017 at 10:38:09 am
As the subject says, I'm trying to render a video with a small animate and then a long period of blank transparency. I have the render set to RGB+Alpha, and everything goes fine while the animation is rendering and the exact frame that the animation is gone it replaces the blank work area with an overlay from a completely different project file. When I scrub through or RAM preview the comp, this doesn't happen; it only happens when I actually render the comp.
I even went as far as to delete the project file this unwanted image is from because I don't need it anymore and it STILL comes up. It's literally pulling an image that doesn't exist on my system anymore. I cleared my cache, databases and whatnot, I don't know where else the system could be pulling this from or, more importantly, what is causing it to, but I have run into the same problem no matter what I do. I've even created new projects to see if it was just a weird fluke with the first one and I am still having this problem.
If anyone has any idea what could be causing this, I'd love some help because I have never seen this before in my life.
Dave LaRonde
Re: After Effects CC is rendering images that aren't even in this project file?
on Mar 15, 2017 at 3:30:14 pm
It sounds like you haven't purged memory & caches for a while. I recommend it. If you've run previous AE versions, I also recommend looking closely at your cache drive. You may find the cache from previous version(s) occupying a lot of space.
Dave LaRonde
Promotion Producer
Michael Szalapski
on Mar 15, 2017 at 6:52:18 pm
Dave's suggestions are great. Do those first.
This is an issue that happened with older versions of AE. What is the exact version number you're using?
- The Great Szalam
