Rendered AE files alpha giving frame glitch on PR render
Michael Melhorn
on Mar 15, 2017 at 1:23:32 am
Hello,
I just started to have a problem with with one of me AE files I have been using for about a year now. It is a transition I use with a alpha channel. In AE it is fine. When i bring in the Final AE file render into PR it is fine inside of the timeline in PR. After I render it in PR is when it get a frame jitter in the area of the video that has the alpha over from the AE file render.
The Render File Properties are:
Type: QuickTime Movie
File Size: 29.94 MB
Image Size: 1280 x 720
Frame Rate: 29.97
Source Audio Format: 44100 Hz - 16 bit - Stereo
Project Audio Format: 44100 Hz - 32 bit floating point - Stereo
Total Duration: 00;00;03;15
Pixel Aspect Ratio: 1.0
Created with: Adobe After Effects CC 2017 (Macintosh)
QuickTime Details:
Movie contains 1 video track(s), 1 audio track(s), 0 closed caption track(s), and 1 timecode track(s).
Video:
There are 105 frames with a duration of 1/29.97th.
Video track 1:
Duration is 0;00;03;15
Average frame rate is 29.98 fps
Video track 1 contains 1 type(s) of video data:
Video data block #1:
Frame Size = 1280 x 720
Compressor = PNG
Quality = Most (5.00)
Audio:
Audio track 1 contains 1 type(s) of audio data:
Audio data block #1:
Format = 16 bit - Stereo
Rate = 44100 Hz
Compressor = 16-bit Little Endian
The PR Sequence that I am putting it into is:
1280 x 720
00;10;16;27, 29.97 fps
44100 Hz - Stereo
VR Projection: None
here is a link to a clip of the video that is having the problem.
New to Creative Cloud. Been coming here for year so figured I should get a account finally. 🐮
Editor/Videographer/TD
Creative Cloud ( AE/PR/PS/AI/ES)
Expression / Maya / 3DS Max
