Random frame issue
David Fleury
Random frame issue
on Mar 14, 2017 at 4:36:30 pm
GRRRR!!
I am trying to render out a project and in my render this frame from a file used in another comp is mysteriously showing up in a different place.
I have emptied all the caches and re started after effects, still there. Anyone else have this issue? Were you able to figure it out?
Thanks in advance.
Dave
Dave LaRonde
Re: Random frame issue
on Mar 14, 2017 at 4:56:08 pm
I'd scrutinize the cache drive if I were you. You may discover the cache from a previous version is eating up a lot of your storage.
Dave LaRonde
Promotion Producer
David Fleury
on Mar 14, 2017 at 5:03:01 pm
OK I will look into that. I have a couple of versions on here.
-D
David Fleury
on Mar 14, 2017 at 9:21:50 pm
That seemed to do the trick. Thanks!
