Question Regarding Particle effect with the use of Images
Josef Brockdorff
on Mar 14, 2017 at 12:10:35 pm
Hi guys,
hope this finds you well.
I need your help since i need to replicate this particle effect with the use of images? was this done with a template or preset?
https://vimeo.com/132082845
Thanks in advance,
Josef
John Cuevas
Re: Question Regarding Particle effect with the use of Images
on Mar 14, 2017 at 1:43:15 pm
Looks like Trapcode Form, using images to control the RGB. Check out these tutorials, couple of the ones at the bottom of the page are what you need.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
