First off, have to say great job on the Skybox Studio V2, composer is great for just jumping into a project and going right away. Very easy to use. Look forward to checking out the new plugins.
Not sure this is the right place, but a suggestion. I found myself having replace some billboards shot in 360 recently and while it's doable with Skybox composer, I found it easier to use Converter and output to a 4:3 cube map. Using corner pin + the flattened views made everything a little more accurate. While using Composer, I tried stepping into the various precomps to get to the flat 4:3 cube map (combine), but that doesn't work only shows the active camera.
If it's possible to add that functionality to Composer great, if not i did figure out the workflow of using Converter, corner/pin, precomp, Convert back to equirectangular.
Either way, another great product, thanks a lot!
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
