Rendering
Lennon KJil
Rendering
on Mar 9, 2017 at 11:35:23 am
I tried to render my video like I normally do.
After I exported it, only one frame showed up.
To test it out, I rendered another random video which rendered perfectly and exported as I wanted it to, only one particular video doesn't.
Is there a reason to this? If so, how can I rectify it?
Daniel Waldron
Re: Rendering
on Mar 9, 2017 at 2:00:43 pm
Is the work area set for the whole area you want to export? What are your render settings?
Lennon KJil
Re: Rendering
on Mar 9, 2017 at 2:43:02 pm
These are the render settings, and yes the work area is set for the area wished to be exported .
Dave LaRonde
Re: Rendering
on Mar 9, 2017 at 3:32:48 pm
Look at the duration in that screen shot. It tells you that the animation begins & ends on frame zero, resulting in a 1-frame animation.
Apparently, AE is doing what it was told to do. Time to look for other explanations. I still suspect a 1-frame work area. It's not tough to set it that way with an accidental hit on the "n" key.
Dave LaRonde
Promotion Producer
Lennon KJil
Re: Rendering
on Mar 10, 2017 at 3:20:21 am
That was it! Thank you!
