Position Key Frame BUG. Argggh!
Brandon Marrero
on Mar 7, 2017 at 10:00:50 pm
I made several key frames to make the red glowing circles stick to his pupils. After I made a pre-comp it made all of my key frames move off of his eyes. I already saved the project and cannot use the undo button. How can I fix this?
Michael Menefee
Re: Position Key Frame BUG. Argggh!
on Mar 7, 2017 at 10:09:24 pm
When you make a pre-comp you select whether to leave attributes in the main comp or to be moved into the pre-comp. No matter what you selected, those keyframes arent deleted.
If the keyframes are in the precomp, try selecting them all, copying, and then pasting on the pre-comp in the main comp. Vice-versa on the other way around.
