Missing basic or standard effect
arya ford
on Mar 7, 2017 at 1:28:59 am
I download a template from my friend .
You can see the missing effect on the picture .
As far as i know, tile is (motion tile) and invert animation is (transform with invert scale) . I have that effect on my after effect . Then why the effect isn't working and not work ?
is he create the effect manually ? because the effect is contain on adjustment layer .
How to find the missing effect ?
I've try the normal way and type "missing" on project search bar, but......there is no missing effect .
It's not "missing effect because of i dont installed the plugin". And i know, if we dont installed the plugin the window pop up will shown and tell us that some plugin isn't installed .
Dave LaRonde
Re: Missing basic or standard effect
on Mar 7, 2017 at 4:24:12 am
It could be a custom animation preset. It's possible to re-name them. You should ask. If it's true, you will need to get the preset.
Dave LaRonde
Promotion Producer
Manuel Taeuber
on Mar 7, 2017 at 1:40:07 pm
Does he has an other version of After Effects? Or maybe another language setted than you?
