Renaming layers as part of a script
Sebastian Törngren
on Mar 6, 2017 at 11:00:29 am
Hi! I am currently working on a rather large script(for me atleast) to add a couple of effects to a source clip. One of those effects requires me to duplicate the layer 3 times, and I wish to rename those layers as well.
I have tried this code but .name does not seem to work for me:
var footage = app.project.activeItem.layer("Footage");
//RBG Split
var channels = ["red", "blue","green"];
var myLayer = footage;
var myName = myLayer.name;
var newLayer;
for (var i = 0; i < channels.length; i++){
newLayer = myLayer.duplicate()
newLayer.name = myName.substr(0,myLayer.length-3) + channels[i];
the script goes through just fine, creates 3 duplicates but does not rename anything.
Any suggestions to what could fix the issue?
EDIT: I just realized that you can swap between Source Name and Layer name in the Layer Editor. I've gotten it to work fine now.
Walter Soyka
Re: Renaming layers as part of a script
on Mar 6, 2017 at 4:39:28 pm
This works. Make sure you're looking at layer names, not source names, in the timeline. Click the the Layer name / Source name column header in the timeline panel to toggle.
As an aside, "myName.substr(0,myLayer.length-3)" probably contains an error, as you're asking for the length of the myLayer layer object. Perhaps you mean for that to be myLayer.name.length-3?
Walter Soyka
