Horizontal alignment of tracked points in Solve camera module in Mocha Pro 5.0
Igor Safin
on Mar 3, 2017 at 10:27:36 am
I have solved a 3D camera movement in Mocha Pro with a pretty great result. When I import tracked data in After Effects the surface I know is horisontal in life is angled in composition (nulls at the corners of surface)
Question: Is there way to align surface I know is horizontal in life, horizontally in composition in After Effects (with camera position also be affected relatevely) or before exporting data from Mocha?
The green line repersents desired result.
Best regards. Igor
Igor Safin
Re: Horizontal alignment of tracked points in Solve camera module in Mocha Pro 5.0
on Mar 10, 2017 at 11:33:28 am
Well, I guess no-one knows ((
Ross Shain
on Mar 22, 2017 at 10:19:46 pm
Currently in Mocha Pro, you will have to align the solved nulls back outside of Mocha.
You may want to look at this tutorial and aescript for orienting the AE camera world:
http://mamoworld.com/tutorials/how-use-orient-world-ae-mocha-camera-solver
Ross Shain
Imagineer Systems
http://www.imagineersystems.com
Igor Safin
on Mar 24, 2017 at 11:37:00 pm
Thanks a lot! It is exactly what I was looking for.
Best regards, Igor
