After effects CS6 - syncing animation to music track
james sandifer
on Feb 24, 2017 at 5:39:35 pm
Hi there,
I'm working with After Effects CS6 on iMac late 2013 3.5 ghz I7 /32bg ram os 10.12.3
I have a dance track which I need to sync animations to but I'm encountering some very basic issues which I'm sure is something to do with my preferences or set up...
I've imported the track into the time line and hit LL to open the waveform but I have encountered to issues with the ram preview.
1. The waveform visualised is not syncing to the audio output properly - I can see an obvious peak in the audio which is the kick drum but when listening to it the kick drum on the track sounds like it is playing early.
2. I have currently got a small section of work area selected - roughly 2 seconds and the Ram preview can't play the audio for the entire 2 s section - it plays the first bit then cuts out.
Has anyone had similar issues?
The track is WAV file.
I really need the visual waveform to display accurately to sync up the animations.
And I need to be able to ram preview the audio and animations.
Any tips would be greatly appreciated!!!
Thank you in advance kind community.
James
