ADBE Vectors Group documentation
rob mcgowan
on Feb 22, 2017 at 4:55:28 pm
hi, anyone know a good source of documentation on ADBE Vectors Group?
All i can seem to find is specific use cases.
Walter Soyka
Re: ADBE Vectors Group documentation
on Feb 22, 2017 at 6:25:39 pm
Other than the Ae scripting guide as a general reference, no.
What is it you're trying to do?
Walter Soyka
rob mcgowan
on Feb 22, 2017 at 8:09:49 pm
hi, I'm writing scripts to build shape layers. So I'm ending up with stuff like;-
contents.addProperty("ADBE Vector Shape - Rect");
var myEllipse = contents.addProperty("ADBE Vector Shape - Ellipse");
myEllipse.property("ADBE Vector Ellipse Size").setValue([controllerSize,controllerSize]);
var myShapeFill = contents.addProperty("ADBE Vector Graphic - Fill");
myShapeFill.property("ADBE Vector Fill Color").setValue(myFillColor);
So, extracting the strings we have
1 ADBE Vector Shape - Rect
2 ADBE Vector Shape - Ellipse
3 ADBE Vector Ellipse Size
4 ADBE Vector Fill Color
5 ADBE Vector Graphic - Fill
6 ADBE Root Vectors Group
Ellipse is Ellipse but Rectangle is Rect. 1 & 2 have "-" signs but 3 & 4 don't. 1 & 2 refer to ADBE Vector Shape and 5 to ADBE Vector Graphic. In 6 Vectors is plural and Root is added.
Without a reference it's a bit hard to determine how the object model in the manual will translate.
rob mcgowan
on Feb 22, 2017 at 8:21:24 pm
And regarding the documentation, I have to wonder what bright spark issued several 200 page help files with neither an index or a table contents. It's deplorable.
Walter Soyka
on Feb 22, 2017 at 8:39:05 pm
[rob mcgowan] "And regarding the documentation, I have to wonder what bright spark issued several 200 page help files with neither an index or a table contents. It's deplorable."
The scripting guide uses PDF bookmarks extensively for organization. Open up the panel on the left in Acrobat.
Walter Soyka
rob mcgowan
on Feb 22, 2017 at 8:45:07 pm
Thanks. I've been opening the docs straight in browser. I'm downloading a proper reader now...
Walter Soyka
on Feb 22, 2017 at 8:38:10 pm
[rob mcgowan] "Without a reference it's a bit hard to determine how the object model in the manual will translate."
Yes, the shape-specific documentation here is slim. You can figure out a lot pretty quickly with this, building shapes in Ae and then exploring their structure with this script:
http://www.redefinery.com/ae/view.php?item=rd_GimmePropPath
Most of what you need to know for dealing with shapes is covered in the sections on the Property, PropertyBase, and PropertyGroup, and Shape objects.
Walter Soyka
rob mcgowan
on Feb 24, 2017 at 11:50:34 pm
Yeah the redefinery rd_gimmeproppath script byJeffrey R. Almasol is absolutely amazing.
I hadn't used it before because the redefinery site only seems to include a later than CS4 version. However the older version is on github and its fine.
It resolved 99% of my After Effects object model questions apart from a few odds and ends like .guideLayer and other stuff which isn't a property one can select in the timeline. The script has a big associative array which links UI stuff to the back end ADBE and that's about as good a reference as anyone could want.
