How do i bend the text on after effects cc 2014 to fit on airplane fuselage
hanna dean
on Feb 21, 2017 at 8:45:05 pm
as u can se the side of the airplane body it rounded and bends , so how do i make my text bent so it fits nicely.
what plugins are their that bends the text to this shape
Dave LaRonde
Re: How do i bend the text on after effects cc 2014 to fit on airplane fuselage
on Feb 21, 2017 at 9:33:20 pm
  • Type out some text to make a text layer.
  • Then make a circle mask on the the text layer -- yes, you can do that.
  • In the text layer settings, make the text follow the mask path.
  • Make the text layer 3D.
  • Rotate & position the text to work with the image.
It WILL NOT be easy to make the text look good on a circular path. Text is meant to appear in straight lines. There will be lots of tweaking involved to make it look nice.
Dave LaRonde
Promotion Producer
Selen Jain
on Feb 22, 2017 at 10:50:36 am
This process is sounding effective, need to try this one!
https://www.clippingpathspecialist.com
Richard Herd
on Feb 21, 2017 at 11:30:22 pm
Cinema 4D is the "normal" application to do that, using mograph > mo text, which is not part of Cinema 4D Lite.
Greg Gesch
on Feb 22, 2017 at 12:01:17 am
Hi Hanna, you might try pre-composing your text then using CC Cylinder on it in your main comp (resize in your precomp if neccessary)?
Eric Santiago
on Feb 22, 2017 at 3:16:18 am
No mention if the film plate is static or if camera moves?
hanna dean
on Feb 22, 2017 at 5:14:54 am
is it possible you can just save the post one image and try edit that and se if u can get it to do what i wnt.
just like how you se real airplanes everyday the text on it i want that affect rather then a strait floating text on top
Tudor "Ted" Jelescu
on Feb 22, 2017 at 7:33:50 am
Free Form V2 or FreeForm Pro from Mettle allow for 3d distortion and displacement. I would use one of these plugins to distort the text/logo layer in 3d and match the perspective of the plane. You can also track the camera move in the shot (if it's a moving shot) and match the move.
Tudor "Ted" Jelescu
Senior VFX Artist
Michael Szalapski
on Feb 22, 2017 at 7:55:33 pm
If the camera doesn't move, Bezier Warp will be perfect.
- The Great Szalam
