Start Trim Path Making Dashed Line Dance
Brandon Davids
on Feb 21, 2017 at 6:50:50 pm
I have created a dashed line on a shape layer and added a Trim Path and I'm trying to animate the start point towards the end point, but it's making the dashes dance around. I suppose I could delete the path and start it from the other end and then animated the End Trim Path (I've noticed the end path doesn't make the dashes dance), but I was just wondering if there is a quicker workaround?
Walter Soyka
Re: Start Trim Path Making Dashed Line Dance
on Feb 21, 2017 at 8:34:52 pm
[Brandon Davids] "I suppose I could delete the path and start it from the other end and then animated the End Trim Path (I've noticed the end path doesn't make the dashes dance), but I was just wondering if there is a quicker workaround?"
You can just reverse the direction of the path. There's a little button next to the path property in the timeline panel that looks like this: . Click it.
Walter Soyka
Brandon Davids
on Feb 22, 2017 at 2:59:25 pm
Thanks, too easy!
