Screen Space Subsurface Scattering with Zdepth Buffer
Hayden Martin
on Feb 18, 2017 at 8:17:03 pm
Hi
I'm looking to use a zdepth buffer from C4D as a way to denoise a render without softening/bleeding hard edges - I created a comp that does this, but only in 8bit (255 black values)... I'd ideally like this running with 32bit... it's super slow too...
This technique could be used interestingly for Screen Space Subsurface Scattering as well. I have seen a plugin for Nuke called DepthVader which does this well.
Is there a plugin or workflow to get this same zdepth based SSSS technique up and running on AE?
Also, why if I input a 32bit image and interpret it's colour values too, the keying effects still only work in 8bit integers? (255, etc)... So frustrating!
Hayden
Walter Soyka
Re: Screen Space Subsurface Scattering with Zdepth Buffer
on Feb 20, 2017 at 2:48:41 pm
[Hayden Martin] "I'm looking to use a zdepth buffer from C4D as a way to denoise a render without softening/bleeding hard edges - I created a comp that does this, but only in 8bit (255 black values)... I'd ideally like this running with 32bit... it's super slow too..."
So you're trying to do a luma key/extract on a depth mass 32bpc to create a matte for a specific range of depth?
Maybe You could create your own by using a couple of precomps (one for the minimum, one for the maximum) with Threshold in each, and the Subtract blend mode to combine them.
Walter Soyka
Hayden Martin
on Feb 20, 2017 at 8:11:32 pm
Hmmm I think you've misunderstood me with regards to the final effect that I want to achieve.
I'm looking to be able to do this in after effects: http://http.developer.nvidia.com/GPUGems/gpugems_ch16.html
Using a Zdepth Buffer, or "depth map", you can create subsurface scattering effects. This is often used in gaming and compositing.
Darby Edelen
on Feb 20, 2017 at 7:36:59 pm
The displayed color values do not necessarily correspond to the internal color values. Check the color display options in the info panel and make sure they're set to Auto or floating point (location and name of options is from memory so may be inaccurate).
Those display values apply to all effects as well.
Darby Edelen
