difference between frame blending & RSMV blur
James Harries
on Feb 17, 2017 at 8:19:39 pm
I am compositing some rendered CG footage out of maya, basically a moving car on a road.
I want the movement to be fluid at 30 fps, so should I aply RSMV blur to my sequence which can simulate motion blur and make thing more fluid or should I simply use AE frame blending option.
What are the pros and cons of each approach?
Dave LaRonde
Re: difference between frame blending & RSMV blur
on Feb 17, 2017 at 9:01:23 pm
It depends on the frame rate of the footage coming out of Maya.
If you want to deliver a 30 (29.97?) file out of AE, I say export out of Maya at the same frame rate. Don't skimp to save rendering time. It isn't worth it in the end.
Dave LaRonde
Promotion Producer
Walter Soyka
on Feb 17, 2017 at 9:28:36 pm
With ReelSmart Motion Blur, you can use a motion vector pass from your 3D render to drive more accurate motion blur than you'd get from either RSMB's or Ae's native motion estimation.
Walter Soyka
Kevin Camp
on Feb 18, 2017 at 12:36:08 am
you can also use the timewarp effect to add motion blur... keep the speed at 100, but enable motion blur.
it's not as good as RSMB, nor as fast... but it's free, and I think it will create a better motion blur than frame blending.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
James Harries
on Feb 18, 2017 at 7:41:59 pm
so the options would be like this (in order of qualirty):
1- RSMV motion blur
2- RS motion blur
3-use simple time warp (enable motion blur)
4-Simply AE frame blending
4-use twixtor (enable built in blending)
right?
