Move Object Without Moving Mask?
C. Blake Davis
on Feb 16, 2017 at 5:26:49 pm
Hello! I have an image file I would like to move WITHOUT moving the mask it contains. Normally I would just use a trackmat, but this image file already has an alpha matte, so I have to use a mask on it to constrain its shape.
Any advice? Thanks so much!
Producer working in NorCal and Nashville
Richard Garabedain
Re: Move Object Without Moving Mask?
on Feb 16, 2017 at 9:12:12 pm
painful situations i know...the only way would be to animate the anchor point but thats only if it has no animation keyframes of anykind currently...which is unlikely
Richard Herd
on Feb 21, 2017 at 11:48:11 pm
The after effects render order is the following:
SOURCE
MASK
EFFECTS
TRANSFORMATIONS
(smet)
Imagine the problems if masks were not on the source. Yikes! Or effects ignored masks!!
Darby Edelen
on Feb 24, 2017 at 4:30:44 pm
However, if you continuously rasterize a layer then the TRANSFORMATIONS stage occurs before the EFFECTS.
This can be useful for effects such as Set Matte where you don't want the matte to travel with the layer's transforms. Of course most footage items don't expose the continuously rasterize switch so this often requires precomposing the footage.
Darby Edelen
Michael Szalapski
on Feb 22, 2017 at 8:32:09 pm
Any chance you could use the Set Matte effect?
(I live just north of Nashville. Nice to see a fellow Tennessean!)
- The Great Szalam
C. Blake Davis
on Feb 24, 2017 at 3:56:52 pm
Unfortunately it doesn't work because the parent layer is a comp, and AE still hasn't corrected their set matte with comp issue.
p.s. I've sent you an invite on LinkedIn. I'd love to connect if you're in the area! I'm about to move into a new place in the Germantown area.
