Is there a way to stop warp stabilizer but keep the framing?
jensen yancey
on Feb 15, 2017 at 4:03:38 pm
I would have thought this problem would come up more often, but I'm having a hell of a time googling a fix. I have a clip that needs stabilization, and warp stabilizer is working perfectly on the problem part of the clip, the issue is there's another section where it just goes crazy. Is there a way to stop after effects (or premiere, if that's easier) from trying to stabilize certain parts of the clip while maintaining the cropping and rotation that it applies to the parts I want stabilized?
Dave LaRonde
Re: Is there a way to stop warp stabilizer but keep the framing?
on Feb 15, 2017 at 6:37:33 pm
[jensen yancey] "Is there a way to stop after effects (or premiere, if that's easier) from trying to stabilize certain parts of the clip while maintaining the cropping and rotation that it applies to the parts I want stabilized?"
AE stabilizes the ENTIRE clip, regardless of in & out points. If you want to stabilize just a portion, you need to import a clip with just that portion.
So to answer the question directly, no. Not in AE.
PP may be a different story, but I don't know that for a fact.
Dave LaRonde
Promotion Producer
jensen yancey
on Feb 16, 2017 at 10:36:30 pm
Well, I guess a better way to ask it is, is there a way to either:
A. easily match up the framing and rotation of a non-warp stabilized clip so there's no visible transition.
B. Tell warp stabilizer to ignore the sections that are causing it to have a seizure.
Dave LaRonde
on Feb 16, 2017 at 10:49:52 pm
Sorry again. The answer to both A and B is "no".
A: Remember, it's a WARP Stabilizer. It fills in missing parts of the image by using something like the Mesh Warp effect... and the amount of warp & where it's applied varies throughout the clip.
B: You'd have to import the "don't freak out" clips separately from the "stabilize this" clips. If they're all contained withing one large clip, you'd have to cut it up into pieces and export them separately for import into AE.
Dave LaRonde
Promotion Producer
Amy Young
on Jul 6, 2018 at 6:48:30 pm
I also wish there were such a feature, something like "Keep the warp/scale settings HERE for n seconds of the clip...."
One thing I do to get frames to line up (as best I can) is to work a while in "Difference" mode for the transparency setting for the "top" layer. I got the idea from stop-motion software. It helps you see what has changed between two frames.
Jim Arco
on Feb 20, 2017 at 1:05:23 pm
I think I would just split the clip "where it just goes crazy" and stabilize the un-crazy clip. You may need to manually move one of the clips so that the beginning/end match up correctly.
Jim
Soham Jani
on Feb 21, 2017 at 12:26:03 am
Yeah, either make another comp and drag the clip in it and shorten it to where you want to do the effect, or cut it up in PP and toss it in AE.
Roei Tzoref
on Jul 7, 2018 at 1:28:35 pm
[jensen yancey] "I would have thought this problem would come up more often, but I'm having a hell of a time googling a fix. I have a clip that needs stabilization, and warp stabilizer is working perfectly on the problem part of the clip, the issue is there's another section where it just goes crazy. Is there a way to stop after effects (or premiere, if that's easier) from trying to stabilize certain parts of the clip while maintaining the cropping and rotation that it applies to the parts I want stabilized?"
Unfortunately, No. it's an automatic tool for better and for worse. you have other methods of stabilizing which are controlled by keyframes like Stabilze Motion (which will use conventional 2d Tracking) or you could use Mocha. there is a tutorial here that offers a workaround for converting WS to keyframes. you can try it:
https://www.toolfarm.com/blog/entry/tutorial_how_to_get_better_control_of_w...
this is a nice FR idea, please add your vote here:
https://adobe-video.uservoice.com/forums/911311-after-effects/suggestions/3...
[Dave LaRonde] "AE stabilizes the ENTIRE clip, regardless of in & out points."
this is incorrect. warp stabilizer will only stabilize between the in and out points of your clip. all you have to do is trim it. this won't help much if it's the same shot because there will be a jump that is impossible to fix.
Roei Tzoref
2D/VFX Generalist & Instructor
♫ AeBlues Tutorials ♫
http://www.tzoref.com
