unable to use Trapcode Mir plugin
Tim Neighbors
on Feb 13, 2017 at 7:27:18 pm
I've been unable to finish a project for about a month now because my Mir plugin appears to have stopped working in the middle of working on it. I was working in an older CS6 version of AE, had built a mountain range with Mir and was flying around it, passing text, etc., when the problems began. I would get error messages mentioning the Mir plugin, the mountains were reduced to shadowless geometric shapes, and I would get errors any time I tried to play the timeline.
Since then, I have upgraded to the latest 2017 CC version of AE, reinstalled the trapcode plugins, and still I have these problems. Even starting a new project, when I attempt to use the Mir plugin with basic Animation Presets, I only see a wireframe and I get the error message:
"After Effects error: MIR: OpenGL error: Could not allocate texFBO (512) (25 :: 241 )"
Here is a video of this issue along with some other strange issues I'm experiencing with this project open and the MIR layer solo'ed.
11042_filefeb13102254am.mov.zip
It can also be viewed here:
I've upgraded to the latest AE version, re-installed the plugin, tried using Adaptive resolution, Draft resolution, Wireframe resolution, "Continuously Rasterize" is not enabled, I've used Classic 3D, Ray Trace, etc. I don't know what else to try. All other Trapcode plugins that I've tried seem to work fine, just Mir that has issues. Could this be a failing graphics card?
Tero Ahlfors
Re: unable to use Trapcode Mir plugin
on Feb 13, 2017 at 8:47:27 pm
Have you tried contacting Red Giant's support?
Tim Neighbors
on Feb 13, 2017 at 9:00:15 pm
Yes, I just did that. I'm still waiting for a response from them.
