Time Lapse, Vanishing Points, Photoshop, After effects, and Image Sequnces.. OH MY
Matthew Dahl
on Feb 7, 2017 at 6:14:33 pm
Hi everyone,
Currently I'm working on a project of a time lapse that shows the construction of offices in side of a building. The Camera shows 3 walls, ceiling, and floor and is stationary the whole time. Now if this was just one 2d image I can use the Vanishing Point filter in Photoshop and then boom ill have a 3d room to use the camera in AE and float around. My question is, is there a way to use the vanishing points filter on every image of the sequence (1 Day is about 400 images) and then just bring it into AE as a comp. Or, is it possible to use the Vanishing point filter on a locked down video showing the same 3 walls ceiling and floor and float around the video.. Thanks in advance!
Walter Soyka
Re: Time Lapse, Vanishing Points, Photoshop, After effects, and Image Sequnces.. OH MY
on Feb 7, 2017 at 6:53:32 pm
Rather than using the Ps Vanishing Point filter, you can re-build the planes in 3D space and use a projection technique to get your free-floating camera.
Here's the idea:
https://library.creativecow.net/devis_andrew/AE-Camera-Mapping/1
Although you can do this with the build-in tools, there are a couple of third-party tools that make it easier:
http://aescripts.com/projection/
http://aescripts.com/buena-depth-cue/
Walter Soyka
Matthew Dahl
on Feb 7, 2017 at 7:45:01 pm
Thank you! Ill give this a shot!
