How can I re-scale a motion path?
Gareth Randall
on Feb 6, 2017 at 2:43:00 pm
I'm bringing a graphic into a 1080 project, scaling it down to 75% so that it fits inside the frame, doing an Auto-Trace, and then copying and pasting the resultant mask path into the Position parameter of a null object to act as a motion path.
Unfortunately, when I do the paste, the motion path is created at the original 100% size of the graphic, so parts of it are out of the frame. I can't find any way to scale the motion path down to match the graphic. The Scale parameter for the null object obviously affects the scale of the null, not the scale of the path.
What am I doing wrong?
Daniel Waldron
Re: How can I re-scale a motion path?
on Feb 6, 2017 at 2:49:21 pm
Double-click a point on the mask before you copy it and then use the outer box points to scale it down. Hold Shift+Command to scale it from center point.
Gareth Randall
on Feb 6, 2017 at 3:04:58 pm
The mask is already the correct size when I copy it. The issue is when I paste it, the motion path it creates is at its original 100% size and I can't find a way to get it back down to 75% to match the scaled graphic.
Obviously I could rescale the graphic in Photoshop before I import it into AE, but I was assuming that AE would have the flexibility to rescale motion paths. Is this another thing that, in fact, it can't do?
Gareth Randall
on Feb 6, 2017 at 3:10:19 pm
Here's the original mask path, created by Auto-Trace after scaling the original graphic down to 75%...
And here's the motion path after it's pasted into the Position parameter of the null - it's back to the original 100% size of the graphic:
guo hehang
on Dec 22, 2017 at 6:00:39 am
Hi, I just got the question too. and i solve it. use the parents. you can new a null1. put the motion path element(just name it:guy1) binding the null1, and here we are, if you scale the null1 to 75%, the guy1's motion path is scaling too, and do one more thing. you put the guy1's scale to 133.33%, the guy1's element became 100% again. so done!
