After Effects Dynamic Link-Server
Marcel Scholz
on Feb 5, 2017 at 1:34:45 pm
Hello,
everytime i export a Comp from AE to Media Encoder it says: "Connecting to Dyna,ic Link-Server" and nothing happens what should i do?
Marcel Scholz
Re: After Effects Dynamic Link-Server
on Feb 5, 2017 at 1:37:48 pm
Dave LaRonde
on Feb 5, 2017 at 4:06:55 pm
I don't trust Dynamic Link to do two-way stuff, ESPECIALLY if it's CC 2017. Lord only knows what sort of mayhem that piece of garbage is introducing.
I foresee two paths you can take:
1) Bite the bullet and just render out your comps using AE in a lossless codec. No AME. Get on with life.
2) Engage in a lengthy diagnostic process to identify the problem. It will probably take days.
The ball's in your court, sir.
Dave LaRonde
Promotion Producer
Julie Zammarchi
on Feb 8, 2017 at 7:11:21 pm
So you mean export lossless from AE, then import said file and export again in AME. Correct?
Dave LaRonde
on Feb 8, 2017 at 7:40:35 pm
Correct. This means that you can ALSO compress for a variety of delivery standards and still maintain as much image quality as possible, rather than having just one file that could be iffy for transcoding.
Dave LaRonde
Promotion Producer
