Video Appears Stretched on IMPORT to AE
Michael Dominic
on Feb 2, 2017 at 3:43:46 pm
I have a video that is Apple ProRes 422, 720 × 480 (640 × 480 Actual).
It appears correctly in QT but when brought into AE it wants to behave as 720 × 480 not 640 × 480, so it is stretched horizontally.
When I make a comp that is 640 × 480 and then 'fit to comp' or 'fit to width' it is stretched vertically.
There has to be a way to fix this without just eyeballing it.
See photo of both QT and AE with the QT specks.
Emre Anil
Re: Video Appears Stretched on IMPORT to AE
on Feb 2, 2017 at 3:54:29 pm
Sounds like a Pixel Aspect Ratio problem.
And make sure you toggle the pixel aspect ratio on viewport:
Michael Dominic
on Feb 2, 2017 at 4:30:35 pm
Thank you. I should have known that.
