layer name vs source name
Jeremy Paul
on Jan 27, 2017 at 6:51:31 pm
What is the difference between Layer Name and Source Name? You can see this 2 option in the Timeline panel.
Walter Soyka
Re: layer name vs source name
on Jan 27, 2017 at 6:56:51 pm
The layer name reflects what something is called in the timeline panel; the source name reflects what that same thing is called in the project panel.
The layer name is initially the same as the source name. But when you rename a layer in the timeline panel, you are changing the layer name; the source name remains the same, referring to the name of the source item.
In practice, I use usually use layer names to be descriptive about what a layer does in the comp, and rely on the source name to tell me what asset the layer uses.
Walter Soyka
Jeremy Paul
on Jan 27, 2017 at 7:19:40 pm
Thanks. I am playing around with ExtendScript. My first obstacle was not knowing what the terms above denote. I am trying to access layer by its name. I use this code, which works if a layer hasn't been renamed yet.
var fl = app.project.item(2).layer("Blue");
var flDupl = fl.duplicate();
If I rename the "Blue" layer, tried both in Timeline and Project panel, to let's say "Blue2", then the code
var fl = app.project.item(2).layer("Blue2");
triggers error saying 'null is not an object'.
Any idea what is going on?
