tracking rotating debris
Marc Nibor
on Jan 26, 2017 at 6:45:16 pm
I got a slowmo shot of small parts of debris which are flying in all kinds of directions (almost like an explosion) and I need to track the position of a few of those parts so that I can attach a small billboard to each of them.
The challenge here is, that the parts that I need to track are rotating in midair and they are blurry too.... so basically I guess I will not be able to do a normal track...
on the other hand, the track does not need to be super accurate... als long as I get the trajectory and speed I can get away with it.
does anyone have an idea what would be the best way to tackle this?
Michael Szalapski
Re: tracking rotating debris
on Jan 26, 2017 at 6:55:56 pm
You could try using Mocha or even AE's point tracker to track each piece and then kinda fake the rotation manually if needed.
- The Great Szalam
Marc Nibor
on Jan 26, 2017 at 8:46:27 pm
Thanks Michael - thank you for your answer.
I think the AE pointtracker and even Mocha will not work - because of the nature of the footage. (i've done a fair amount of tracking in the past) The good thing is that I do not need the rotation - only the position. Anyhow... I'll give it a try now.... but my hopes aren't up ; )
