AE COMP Name Script
Philip Francís
AE COMP Name Script
on Jan 25, 2017 at 12:09:53 am
I have this script which grabs the name of the top most layer in AE.
txt = "";
for (i = 1; i <= thisComp.numLayers; i++){
if (i == index) continue;
L = thisComp.layer(i);
if (! (L.hasVideo && L.active)) continue;
try{
txt = L.source.name;
}catch(err){
txt = L.name
break;
txt
Any way to change it so it grabs the lowest layer in the comp..?
Walter Soyka
Re: AE COMP Name Script
on Jan 25, 2017 at 2:30:35 pm
Point of pedantry: this is an expression, not a script. Expressions are evaluated, calculated as values for properties on-the-fly, as the comp renders. Scripts are executed and perform actions.
If we change the for loop, we can make this expression grab the name of the source of the lowest active layer:
txt = "";
for (i = thisComp.numLayers; i >= 1; i--){
try{
}catch(err){
txt = L.name
break;
txt
Walter Soyka
Philip Francís
on Feb 5, 2017 at 5:48:14 pm
Thanks, cleared up a major problem I was having!!
