SSD as After Effects Disk Cache turning itself off / not working properly
Nemorin Client
on Jan 23, 2017 at 11:23:06 am
Hi guys,
We bought an internal SSD hard drive - Samsung 850 EVO PRO (512gb) (by accident)
And ended up buying a PNY 2.5in Drive Enclosure to use with the Internal SSD with the USB 3.0 port of the imac
This SSD was intended to be used as a Disk Cache for After Effects, but it just stops working after some time when I'm working on After Effects.
I can work from 15min to 1 or 2 hours without any problem, then suddenly AE becomes very slow, and I notice the light on the enclosure turned off (when is writing/reading is blinking blue),
The drive is still "on" on Finder, but when I click on it it takes 5 to 10 min just trying loading (no folder inside the SSD loads) and the finders stops working.
I've already:
- Changed the USB port it was connected and still got the same problem
- Changed the USB cable that connects the enclosure to the iMac - same problem
- Changed the PNY enclosure to a new one - same problem.
I haven't changed the Hard Drive itself, and I would like to erase all other possibilities before I try that...
Maybe there's a proper way to set up the SSD for AE?
Before I was using a LACIE normal HD thorough Tunderbolt as Disk Cache and I haven't had any problems.
(but I can see the speed difference of the SSD when it actually works)
I'm using an iMac 27-inch late 2013 - OS X 10.10.5
And After Effects 2015.3
The error actually happen once while it was rendering... that's what showed up in the log:
Adobe After Effects v13.8.1 Macintosh 64 render log for project “project_012.aep”
Rendering started on 23/01/2017 at 10:19:56 GMT
23/01/2017 10:19:56 GMT: Starting composition “FACTORY_SCENE2”.
Output To: /Volumes/Public/PROJECTS/ONGOING/Parcelive_090116_CFVxxxx_/Exports/WIPs/Scene_2_3_4_WiP003.mov
After Effects warning: Unknown file i/o error
After Effects warning: Could not create the file '/Volumes/DiskCache/AfterEffects/Adobe/After Effects/13.8/Disk Cache - Pete’s iMac (2).noindex/ab/ab09bc3c-adf4-3d48-04f5-5d7a481833ab.ADBE LCV.76C0E26.BQAAAAYAAAAUAAAAFAAAAAUAAAAGAAAAFAAAABQAAAAFAAAABgAAABQAAAAUAAAAAAAAAAAAAAAZAAAAGQAAAAAAAAA=.aecache.tmp'.
After Effects warning: Could not create the file '/Volumes/DiskCache/AfterEffects/Adobe/After Effects/13.8/Disk Cache - Pete’s iMac (2).noindex/99/99d41c41-adc8-5ed7-317e-1cc7674ee13d.ADBE ICV.76C0E26.AAAAADIAMgA=.aecache.tmp'.
After Effects warning: Could not create the file '/Volumes/DiskCache/AfterEffects/Adobe/After Effects/13.8/Disk Cache - Pete’s iMac (2).noindex/5f/5fc9c4ef-4230-5d19-f511-a91e417435e8.ADBE LCV.76C0E26.BgAAAAQAAAATAAAAFgAAAAYAAAAEAAAAEwAAABYAAAAGAAAABAAAABMAAAAWAAAAAAAAAAAAAAAZAAAAGQAAAAAAAAA=.aecache.tmp'.
After Effects warning: Could not create the file '/Volumes/DiskCache/AfterEffects/Adobe/After Effects/13.8/Disk Cache - Pete’s iMac (2).noindex/17/174f142a-bee0-1a88-15cd-ed6371e882db.ADBE ICV.76C0E26.AAAAADIAMgA=.aecache.tmp'.
Render stopped by user.
23/01/2017 10:39:52 GMT: Finished composition “FACTORY_SCENE2”.
Total Time Elapsed: 15 Min, 58 Sec
Log closed on 23/01/2017 at 10:39:52 GMT
