Render missing content
assaf tshuva
on Jan 22, 2017 at 12:01:43 pm
hi,
I'm trying to do the simplest thing - render a sequence of 10 images (CS6).
I have a precomp of 10 images, which placed twice on the main timeline, and I render the sequence as a WMV (directly from AE).
When I watch the final video - some of the images "get stuck" for longer than they should (the video keeps running), and so the successive images just don't appear. The sequence appears twice, and on each sequence other images get stuck and for different time.
I shrank the images size quite a lot, restarted and kept cleaning the cache, but it changed nothing.
What could be the problem?
chris brett
Re: Render missing content
on Jan 22, 2017 at 1:03:12 pm
Hi --- do they look ok on the preview before you render ---c---
assaf tshuva
on Jan 23, 2017 at 10:02:05 am
Chris - The sequence runs OK on preview and during rendering, but not in the output file.
Dave - The output file is rendered as WMV with an average bit rate, there is no problem of codec or file size (if I understood the link content correctly).
