Problem with Keyframes
Giorgos Chatzigrigoriou
on Jan 7, 2017 at 12:59:19 am
Hi there, I have a weird issue with after effects. It's been a long time since I've used after effects so maybe it's the way it works. Let's say I keyframe the position of the video. When I playback the footage it doesn't show the values gradually changing. The effect is happening but the numbers are the same. Also when I click on each keyframe to see the values again it doesn't change. The values change only when I drag the cursor timeline manually or when during playback I pause and then it shows the values for the specific time. Any help will be appreciated.
