3D transparent Object Problem
Christian Demxix
on Jan 6, 2017 at 4:56:45 pm
So I have a problem when I rendered a 3D object, it has lines every where when the object is moving. There is no wires/lines visible when I previewed the video but after I rendered it, it is everywhere. I put this 3D object/video in front of another video that serves as a background. I'm still new at after effects.
https://snag.gy/bSo8gq.jpg here is the screenshot. as you can see the white lines are visible.
Dave LaRonde
Re: 3D transparent Object Problem
on Jan 6, 2017 at 6:07:37 pm
That's the outline of another layer.
You really, Really, REALLY need to spend some quality time here:
https://helpx.adobe.com/after-effects/tutorials.html
Blow off those YouTube tutorials made by high school kids. Get your learnin' from the Pros.
Dave LaRonde
Promotion Producer
Christian Talban
on Jan 7, 2017 at 8:27:46 am
Then how can I remove it? is there a way that I can remove it?
Roei Tzoref
on Jan 7, 2017 at 10:47:22 am
I am not sure what you mean. Show us the video or some part of it. You can drag and drop to the text field.
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
Christian Talban
on Jan 7, 2017 at 3:29:50 pm
Here it is. It is just a short clip. You can see that there are so many lines around the video or object (the cube).
10932_03.main.mov.zip.
Roei Tzoref
on Jan 7, 2017 at 4:04:51 pm
these lines are also apparent in the preview screenshot you showed before.
this is the screenshot you showed before
this is a frame from the video:
these look very similar to me. maybe showing another frame in time or different background (this could be that you are having no solid black background in Ae.
how did you composite this 3d object? was it through a plugin? these lines are originated from some sort of effect or plugin.
we need more information about this setup and you should isolate the problem to see exactly what's causing the differences if you see any.
Roei Tzoref
Mahmoud Jaber
on Jan 8, 2017 at 6:38:28 am
This is probably because you're using a trial version of a third party plugin.
