Setting position of particles?
Samuel Hinton
on Jan 6, 2017 at 6:04:05 am
Hi guys,
I've been tasked with creating some visualisations of galaxy surveys for my cosmology group, and at the moment I have simply written some python code to output plots, which I animate manually, and have manually had to code additive blending. It is not ideal. Video in question is here:
I would like to move to AfterEffects using some particle system (inbuilt/particular/other), because it would make life a thousand times easier. However, I cannot find a way to manually set particle positions. I have the x,y,z coordinate of each particle, and can save them out to csv or any format, however I cannot find a way of importing those positions into AE and using them in a particle system!
Does anyone know of a way to do this?
Cheers
Walter Soyka
Re: Setting position of particles?
on Jan 6, 2017 at 4:16:40 pm
I don't know of any particle system for Ae that lets you manually place particles; they all work based on emitters or arrays.
Walter Soyka
Shawn Miller
on Jan 6, 2017 at 7:12:46 pm
Hey Samuel,
It sounds like you're really trying to generate a dense point cloud. You might not be able to do this with a particle system, but you might be able to do it with a 3D tracking system like Syntheyes, Boujou, PfMatchit or possibly AE. You already have the coordinates of the objects you want to represent, so you just need to put them in a format that a 3D tracker can understand. After that you'll need to shade those points, but I imagine you could just generate a mesh from those points and then render the vertices - maybe using something like Trapcode Form.
Shawn
Samuel Hinton
on Jan 8, 2017 at 4:39:01 am
Hi all,
Thanks for the suggestions, especially to Shawn. I was able to export my points manually to an obj file and import that using Trapcode form!
Cheers
