After Effects: Mouse dragging issue (Real Time?)
Donovan Lewis
on Jan 4, 2017 at 6:51:33 pm
Hi
I have always been working with Adobe After effects Cs3. I have upgraded my system to a 16GB Ram, windows 10 OS and adobe cs6. Ive been having this issue and its quite hard to get the answer as its explanation makes it so difficult.
So here's my issue: When I have created my composition and have added anything, weather it be a rigged character or even just a normal shape. When dragging it across the screen ( with the left mouse button) on the work area nothing is visible (no movement) until i leave the mouse button it only appears where i ended. But no movement in between was visible.
I have read numerous threads but couldn't come across anything such as this and as I said before, its quite difficult to explain. It has nothing to do with pre- or rendering. Its the actual moving (visibility) of an object when dragged by the mouse. I have set my resolution down to Quarter to see if that might be the issue but nothing (I even have 14GB of RAM allocated to Adobe Products so the chances are slim of it being this).
