After Effects rendered through AME gave jerky animation
Syed Iqbal
on Dec 31, 2016 at 12:09:21 am
I imported png sequence into After Effects which was rendered at 29.97 fps from C4d and getting this jerky playback that you can notice after 4 secs onward.
AE interpreted as 30 fps that I forced to actual 29.97 fps but still getting this problem and unfortunately I have no clue on this. Output file link is copied below, please come up with your suggestions if possible to resolve this.
Output from AE using AME was H264 @ 29.97 fps
https://www.dropbox.com/s/a3n1ed7aeoevgri/trinagle%20green.mp4?dl=0
Thanks in advance.
Syed
Syed Iqbal
Re: After Effects rendered through AME gave jerky animation
on Dec 31, 2016 at 6:46:54 am
Just to clarify, I exported PNG sequence from C4D and imported that as footage in AE because I wanted to apply certain effects in After Effects.
Roei Tzoref
on Dec 31, 2016 at 5:44:49 pm
I suspect this is a GPU rendering issue. try this - in the Queue panel in AME use "Mercury playback engine software only" as your renderer and not and not "GPU" and try again.
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
