Freeze Comp and play animation in it while freezed
Walter Stichelt
on Dec 30, 2016 at 10:13:54 am
Hello everyone, i hope you survived Christmas well.
Is there any possibility to play a video/animation in an freezer comp?
I have a 3d Animation and need to stop it for some seconds to play a video on a solid with 3 informations.
How can i freeze the Animation and play the video inside?
chris brett
Re: Freeze Comp and play animation in it while freezed
on Dec 30, 2016 at 10:36:53 am
Hi Walter
--- if I understand correctly I think you can do this by duplicating the layer - freeze the bottom layer - then mask the top layer so that it shows desired area only
----------------------------- chris --
Walter Stichelt
on Dec 30, 2016 at 12:42:03 pm
Hm no that won't work in that case.
I have a rendered 3D animation, 3D solids and a 3d Camera.
What i try to do now is, i still use time remapping on the main animation, duplicate the keyframes wit the 3D data onto an new comp and just move the keyframes and create that break that i need.
That seems to be the easiest way right now.
chris brett
on Dec 30, 2016 at 12:53:15 pm
..... I see -- theres also .....
1 - duplicate comp
2 - hide ( or delete ) elements you want to keep moving in bottom comp and freeze bottom comp
3 - hide ( or delete ) elements you want to freeze in top layer
--------------------- think this should do it ( ? ) -- but if not sounds like you have it covered anyway ?
---------------------------------- all the best -----chris ---
